Connection Problem
Soulya 5 years ago • updated by Stupiddog 4 years ago • 4
game4automation: Object [Siemens S7] TCP : Connection Error: Siemens S7 (game4automation.S7Interface)
UnityEngine.Logger:LogError (string,object)
game4automation.Game4AutomationBehavior:Error (string,object) (at Assets/game4automation/private/Game4AutomationBehavior.cs:496)
game4automation.S7Interface:ConnectS7 () (at Assets/game4automation/private/Interfaces/S7TCPIP/S7Interface.cs:496)
game4automation.S7Interface:CheckConnection () (at Assets/game4automation/private/Interfaces/S7TCPIP/S7Interface.cs:478)
game4automation.S7InterfaceEditor:OnInspectorGUI () (at Assets/game4automation/private/Interfaces/S7TCPIP/Editor/S7InterfaceEditor.cs:31)
How to solv this Problem?
You could youse PLCSIM Advanced or PLCSIM with NetToPLCSim (https://mirror-networking.com/docs/).
Second solution should work but it is not officially supported.
Hi, there is a problem to connect to your PLC.
Please check if you could ping the PLC's IP address.
Turn off all firewalls on your computer
Configure your PLC with TIA portal like described here: https://game4automation.com/documentation/current/s7tcpip.html#Configuring-the-PLC
So it is important to have a Real CPU to connect to use Game4automation. I though that i can also simulate because i don't have a real plc. Is there a way to simulate without cpu in Tia Portal and Game4Automation or not?
Hello,Thomas,I want to use PLCSIM and NetToPLCSIM connect unity because it support S7-1200CPU without real PLC,witch Interface should I use?PLCSIMADV or S7Interface?Should I set something in Portal or unity?Thank you!
