Import signals error in Twincat Interface
Stupiddog 4 years ago • updated by Support 4 years ago • 5
Hello Thomas,I build a Test program with Twincat3,after I press Active configration button thePLC turns green then I press Import Signals in Unity it shows:TypeLoadException: Could not resolve type with token 0100000a (from typeref, class/assembly I18N.Common.MonoSafeEncoding, I18N, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756) assembly:I18N, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 type:I18N.Common.MonoSafeEncoding member:(null) signature:
System.RuntimeType.GetConstructors_internal (System.Reflection.BindingFlags bindingAttr, System.RuntimeType reflectedType) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.RuntimeType.GetConstructorCandidates (System.String name, System.Reflection.BindingFlags bindingAttr, System.Reflection.CallingConventions callConv, System.Type[] types, System.Boolean allowPrefixLookup) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.RuntimeType.GetConstructors (System.Reflection.BindingFlags bindingAttr) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.RuntimeType.CreateInstanceImpl (System.Reflection.BindingFlags bindingAttr, System.Reflection.Binder binder, System.Object[] args, System.Globalization.CultureInfo culture, System.Object[] activationAttributes, System.Threading.StackCrawlMark& stackMark) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.Activator.CreateInstance (System.Type type, System.Reflection.BindingFlags bindingAttr, System.Reflection.Binder binder, System.Object[] args, System.Globalization.CultureInfo culture, System.Object[] activationAttributes) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.Activator.CreateInstance (System.Type type, System.Reflection.BindingFlags bindingAttr, System.Reflection.Binder binder, System.Object[] args, System.Globalization.CultureInfo culture) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.RuntimeType.InvokeMember (System.String name, System.Reflection.BindingFlags bindingFlags, System.Reflection.Binder binder, System.Object target, System.Object[] providedArgs, System.Reflection.ParameterModifier[] modifiers, System.Globalization.CultureInfo culture, System.String[] namedParams) (at <695d1cc93cca45069c528c15c9fdd749>:0)
I18N.Common.Manager.Instantiate (System.String name) (at <6abb78bbc2d24347bb608e81ff4eb73b>:0)
I18N.Common.Manager.GetEncoding (System.Int32 codePage) (at <6abb78bbc2d24347bb608e81ff4eb73b>:0)
System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <695d1cc93cca45069c528c15c9fdd749>:0)
Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation.
System.Text.EncodingHelper.InvokeI18N (System.String name, System.Object[] args) (at <695d1cc93cca45069c528c15c9fdd749>:0)
System.Text.Encoding.GetEncoding (System.Int32 codepage) (at <695d1cc93cca45069c528c15c9fdd749>:0)
TwinCAT.Ads.Internal.SymbolUploadInfo.get_StringEncoding () (at <23b243ab6b58458a8536a564d2211fbc>:0)
TwinCAT.Ads.TcAdsSymbolInfoLoader.onUploadSymbols () (at <23b243ab6b58458a8536a564d2211fbc>:0)
TwinCAT.Ads.TcAdsSymbolInfoLoader.initializeUploadSymbols (System.Boolean forceReload) (at <23b243ab6b58458a8536a564d2211fbc>:0)
TwinCAT.Ads.TcAdsSymbolInfoLoader.GetSymbols (System.Boolean forceReload) (at <23b243ab6b58458a8536a564d2211fbc>:0)
game4automation.TwinCatAdsInterface.ImportSignals (System.Boolean simstart) (at Assets/game4automation/private/Interfaces/TwinCAT/TwinCatAdsInterface.cs:351)
game4automation.TwinCatAdsInterface.Import () (at Assets/game4automation/private/Interfaces/TwinCAT/TwinCatAdsInterface.cs:747)
System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at <695d1cc93cca45069c528c15c9fdd749>:0)
NaughtyAttributes.Editor.NaughtyEditorGUI.Button (UnityEngine.Object target, System.Reflection.MethodInfo methodInfo) (at Assets/game4automation/private/Tools/NaughtyAttributes/Editor/Utility/NaughtyEditorGUI.cs:179)
NaughtyAttributes.Editor.NaughtyInspector.DrawButtons (System.Boolean drawHeader) (at Assets/game4automation/private/Tools/NaughtyAttributes/Editor/NaughtyInspector.cs:188)
NaughtyAttributes.Editor.NaughtyInspector.OnInspectorGUI () (at Assets/game4automation/private/Tools/NaughtyAttributes/Editor/NaughtyInspector.cs:52)
UnityEditor.UIElements.InspectorElement+<>c__DisplayClass59_0.b__0 () (at :0)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr, Boolean&)
Image 643
Image 644
Image 645
Image 646
Image 647
My Unity is 2020.3.4 and G4A is Version 2020.15 - February 10, 2022,Thank you Thomas。
could it have to do with some non english letters in the symbol naming. I know that this problem exists and we need to fix it in one of the next releases.
OK,thank you very much,I will try it later。
Hello Thomas,Could you send me a simple Twincat 3 program?I want to test if I can control my PLC with Unity。Thank you very much!
Hello Thomas,I add 6 BOOL variables(A、B、C、X、Y、Z),when I Import signals it shows errors too。Even I build 2 BOOL variables it also shows error when I start。I notice the Port is 33634 in Twincat,but it shows disconnect when I input this,851 is connect。What should I do?Do I need set something in Twincat or Unity?I watched your video and it runs well but I can't connect。
I am pretty sure that your variable naming is wrong. Best way is to import the variables from the PLC.
