Robot pick and place task
Kadir 4 years ago • updated by Support 4 years ago • 3
i would like to do a pick and place task in unity. is it possible with realvirtual or do i need any plugins (robotstudio, roboDK)
and how ?
PS: i use the starter version
Sie könnnen in Simit die Achswerte mit dem spezifischen ABB RobotStudio Interface empfangen und per Shared Memory Simit Interface an realvirtual.io übertragen.
https://search.abb.com/library/Download.aspx?DocumentID=9AKK107492A4208&LanguageCode=en&DocumentPartId=&Action=Launch
https://realvirtual.io/documentation/current/sharedmemory.html
Wie gesagt in der Professional Version geht es direkt - in der Starter leider nur über den Simit Umweg.
in the Starter Version there is no direct robot interface (e.g. Universal Robots or RobotStudio) included. Also the inverse kinematics (https://realvirtual.io/documentation/current/robotik.html) is not included which we have in the professional version.
For moving a robot the possiblities in Starter are very limited:
- you could move the axis itself - but this is very uncomfortable if you would like to reach a certain TCP-Position
. you could use the Simit interface (which is included in Starter) and use Simit robot interfaces - but you would need to get a Simit version and I am not sure if the robot interfaces will work in Simit demo. Here you can see which kind of interfaces are supported by Simit (https://support.industry.siemens.com/cs/document/109795246/simit-kopplungen-applikative-erweiterungen-der-schnittstelle?dti=0&lc=de-DE)
Hallo,
Auf Anfrage habe ich Zugriff auf Simit V11 bekommen. Ist es damit möglich die Simulation von RobotStudio auf Unity zu übertragen?
