Hello Thomas,Can I use Ethernet IP get every axis float value from RoboGuide?
Stupiddog 4 years ago • updated by efrensilveyra 4 years ago • 4
If I want to do as the video shows(
Youtube video
)He used Ethernet IP too。But witch type should I choose?Thank you very much。
Hi, I never  tried Roboguide and EthernetIP. Are you sure that roboguide is able to communicate over EthernetIP. We don't have RoboGuide - so we realy don't know what do do in your case. Sorry.
That will be awesome.
For now what I do to communicate Roboguide with Unity is through the PLC
yes through the PLC might be a good choice. Do you know any kind of protocol we could use to communicate with Fanuc Roboguide?
In Roboguide there is an option for adding external devices (an OPC), some people use KepserverEX to communicate the Roboguide with the PLC, in youtube are videos about that.
