[Help Needed] OPC UA Signal Direction Imported Incorrectly (Inputs recognized as Outputs and vice versa)
王海星 9 months ago updated by Lei 2 months ago 4
Hi everyone,
I'm working with the OPCUAInterface component in realvirtual.io to connect Unity to a Siemens S7-1500 PLC via OPC UA, and I'm running into a frustrating issue with signal direction mapping.
Setup:
  • PLC: Siemens S7-1500
  • Unity side: Using OPCUAInterface from realvirtual.io
  • In the PLC (TIA Portal), I've configured:
    • .inputs variables as Read-Only (HMI accessible: Read only)
    • .outputs variables as Read/Write
  • In Unity:
    • I've tried enabling/disabling Automatically Input On Write Signals
    • I've set Regex Write Nodes = (?i)\.outputs to match output variables
However, no matter what combination I try, the imported signal directions are reversed:
  • .outputs are imported as Input ❌ (they should be Output)
  • .inputs are imported as Output ❌ (they should be Input)
 What I Expect:
Based on my understanding of realvirtual.io's signal model:
  • Input = Unity reads from the PLC (e.g., sensors, status)
  • Output = Unity writes to the PLC (e.g., buttons, control commands)
I expect .inputs to be imported as Input, and .outputs as Output.
 Temporary Workaround:
I'm currently using a custom Unity script that runs after import and forcibly sets the signal direction based on the variable name (.inputs → Input, .outputs → Output).
This works, but feels like a hack and not a long-term or scalable solution.
What I'm Asking:
  1. Is this a known limitation of Siemens OPC UA Server? (Does it misreport variable access rights?)
  2. Is there a way to fully customize signal direction logic during import in OPCUAInterface?
  3. What’s the recommended best practice for Siemens OPC UA + Unity signal mapping?
our naming convention is always from the point of view of a plc so “PLCInputBool” is a bool input of a PLC – what means a Bool output of Unity.
This hopefully already answers your full question.
Set it to "Read-Only (RD)" mode in the OPC UA Server Interface, and then it can be normally read as an input signal for Unity,sorry for my question
你好,我也是中国区使用者,方便的话加我下Wechat:410701881,在RealVirtual.io使用中发现了不少问题
I‘m chinese too! 这是我的微信号:18986104747,使用过程中有问题一起交流研究一下。
