[Help Needed] FANUC RobotInterface
BWA vor 12 Monaten • aktualisiert von Support vor 11 Monaten • 3
Hi everyone,
I'm working with the FanucInterface component in realvirtual.io to connect Unity to RoboGuide.
I'm able to connect Unity and Roboguide through SNPX
I'm able to read UO and DO signals from the robot in Unity but I'm not able to write DI or UI signals.
Setup:
  • RoboGuide: HandlingPro Classic Version 10 (Rev.C_SR4)
  • Unity: Unity 6.2 with realvirtual.io V6.0.7.8152
Hi, we will check if this could be a bug. Will let you know asap the next steps. Best regards Thomas
Is solved - will be available next week in V6.0.7 update / patch
