Realvirtual-WEB ReqList
陈喜成 2 months ago • updated 2 months ago • 1
I'm glad to test your company's product.The feedback on the RealvirtualWeb functionality test is as follows:
UnityToWeb:
1. Mesh cutting ineffective DemoCSGMachining
2. Hinge ineffective DemoKinematicsSolver
3. Robot time speed change ineffective DemoRobotIK
Web/GLB/Interface:
1. S7 ImportTagTable does not support DB (hope to support import/export, and native TIA exported columns need manual modification to import) [OK]
2. S7 ImportTagTable direction cannot be automatically recognised (ReadFromPLC / WriteToPLC) [OK]
3. Large GLB file export [WebViewer] Export failed: System.IO.IOException: Stream was too long. (deduplication skipped, causing unprocessed data to exceed 2 GB MemoryStream, not an issue with GLB size itself.) [OK]
4. Start Dev Server/Open in Browser (localhost:5173) loading the current model sometimes causes web errors [OK]
"realvirtual WEB OPEN. LIGHT.INDUSTRIAL. ANYWHERE.Could not load the model Unexpected token"
5. OPC UA browser only shows the top-level nodes (subnodes not traversed?)
The OK items were fixed by AI, OPC UA still awaits official update. Thanks in advance~
