Review written. Thanks again. Andy
Hi.
I was getting:
error CS0246: The type or namespace name 'UnityScript' could not be found (are you missing a using directive or an assembly reference
but it appears that you aren't using UnityScript so I removed this line..
I tried it on our large assembly and it all works well.
Thanks for the excellent support.
Andy
Step file sent.
Thanks for your help. Have a good weekend.
You should have received the files.
Further investigation makes me think I am only getting the problem with assembly positions when the data originated in a STEP file (although the 3mf file reads ok into other tools we have that read 3mf). Native Solid Edge models are importing ok.
Thanks for the quick response.
I can confirm that fixes the colour problems.
I can't share the assembly we are having problems with as it's confidential. I will try to generate a model that replicates the problem.
Thanks
