Hey Thomas,
I have implemented your beta solution in my example program with the SharedMemoryInterface and its working really well, nice job !
After that i switched to the OPC-UA interface to see if that is working the same, but I don’t get a event when a PLCOutputBool is changing.
Is it possible to get the same behavior in the OPC-UA interface?
Best regards,
Tim
Hi Thomas,
Yes i have set up Simit as OPCUA server and this is working.
We use logic in the Simit.
I will send a mail to info@game4automation.com with my invoice number.
I also left a review in the asset store :)
Best regards,
Tim
Hey Thomas,
Thanks for thinking along, we use Unity for making DigitalTwins of tunnels and bridges so there are a lot of IO’s, but they are not changing that often.
We are using OPCUA in our projects between control and Simit.
I am looking to the possibilities of the OPCUA driver now.
Your new solution looks really promising, will this solution work for SHM and the OPCUA interface?
I am looking forward to the beta version
Best regards,
Tim
Hey Thomas,
Thanks for looking in to this!
Yes we want a event when a value is changed in the interface.
We are working on large projects, where we have 1000 - 20.000 variables in Simit.
Checking all those variables in the update method would cost a lot of resources.
So we try to avoid the update method where we can.
Would it be possible to implement a on changed event like the "PLCOutPutBoolChanged" event when a variable changes in the interface, in the next release?
Best regards,
Tim
Hey Thomas,
Thanks for the response, I will send a Unity Project to info@game4automation.com
Tim
Hi Thomas,
I looked in my "Scripting Define Symbols" and GAME4AUTOMATION and GAME4AUTOMATION_PROFESSIONAL where already there.
I have set up a connection to a SIMIT OPC UA Server, and the system variables in the folder "Server" are working fine.
They get a PLC script added to them.
But if i add Variables in Simit and go to the folder InSimitOpcBin where my custom variables are. the dont get the PLC Output script
