S7 interface problem
D St 6 years ago in realvirtual.io Starter and Professional updated by Support 6 years ago 3
I was following the youtube tutorial on how to connect Unity with S7 controller (in my case 1500).
After I successfully checked the connection and added PLCTags sdf file, made a fast test scene but when I Play it I have the following messages cycling:
Image 200
Image 201
Image 199
Any suggestions ?
You are welcome, please give us a good rating in the Unity asset store if you are happy with our solution - thanks!
BAD, I'M UNSATISFIED
Satisfaction mark by D St 6 years ago
Did you configured it on the PLC side like described in the document below:
https://game4automation.com/documentation/current/s7tcpip.html
Yeah, I didn't see that document... Thank you for your help :)
