Compile Problems with demogame4automation
SCT FPG 6 years ago in realvirtual.io Starter and Professional • updated by Support 6 years ago • 4
Hello I recently purchased the game4automation asset to test the features that it offers but I´m having problem with the demo compilation..
I followed the guide but unfortunately due to the new versions of unity, some steps are different.
Those are some of the errors that i get when I try to run the demo:
Image 221
And for example when I configure the "build project settings" I cannot find the called "scripting runtime version" and maybe that's the reason.. I just can configure following:
Image 222
Do you have some Idea what is going on?
It should work with some minor changes which you would need to do on your own. Officially, we only support latest LTS releases.
I had a similar problem with the Unity version2020.1.3f1. With version 2019.4.9f1 it worked without problems.
David
Hi! I fixed it by converting all my files to the 2019.4.13f1 unity version.
I do not think that the beta or the 2020 version is supported.
Hi, it is hard to say what the problem is. Generally we only support and test with the latest Unity LTS Release (which is Version 2019.4). I am sure that you could get it running with 2020 but that might require some changes.
If you don't get it working with 2019 you could send me your project and I will check what the problem is.
