Sensor "Limit Sensor To Tag" null Error
DAT vor 5 Jahren in realvirtual.io Starter and Professional aktualisiert von Support vor 5 Jahren 3
I have encountered a few error from sensor script:
The sensor script throws a null error when using the "Limit Sensor To Tag" function unless the parent object have a MU.
Even though I am using the "Limit Sensor To Tag" function the sensor still gets trigger by the parents objects of the object that have the tag. (Parents objects do have mesh collider attached)
Hi Dat, I just checked. Objects wich are colliding with the Sensor must alway have the MU script on the same or in a level above the collider. This is the planned behaviour. I don't know in what combinatione exactly your problem comes up. Can you send me a simple example?
Hi Dat, will need to check that. Most probably I will get back to you tomorrow!
