Reading many inputs
Willem Van Der Gaag 5 years ago
updated by Support 4 years ago •
Hi! Is it possible to acces all the inputs at the same time. I would like to write all the values of these to a file for future reference. Thanks in advance!
You could loop through all Signal objects in a script each FixedUpdate and read Signal.Value for saving it to whatever format you would like.
