HI
tongtiangumu 5 years ago in realvirtual.io Starter and Professional • updated by Support 5 years ago • 1
Image 488
Hi, you seem to have errors in your project but I can`t see which errors. Based on the latest review on the Unity asset store (which might be from you) you might have multiple identic dlls in your project. This is normally if you are using multiple assets which are using the same dlls. You need to delete on of these duplicated dlls because they are only allowed to be once inside. O
