vs code can open script, vs2019 unsupport open script
If i set script open by vs code, it could be open C# behavior script.
if i set script open by visual studio 2019, it could't open C# behavior script.
it is only support vs code ?
Roy
Hi, I would recommend Visual Studio 2019 - which is usually used. I have seen some customers using Code but I would not recommend it, because there might be some limitations. We are using Rider for development which is also very good with Unity but Rider is not for free.
If you have problems in using Visual Studio 2019 this is a general Unity or Visual Studio installation or setup problem.
Please follow this guide:
https://docs.microsoft.com/en-us/visualstudio/gamedev/unity/get-started/getting-started-with-visual-studio-tools-for-unity?pivots=windows
