OPCUA with 2020.15 Doesn't Import Arrays
Neil 5 years ago in OPCUA4Unity • updated by Support 5 years ago • 2
Hello. I have setup an OPCUA Client without issue on several versions of Unity (2019.4.18f1, 2020.3.25f1) with game4automation 2020.13.
I now seem to have an issue Importing array nodes after an update to game4automation 2020.15.
The nodes import, but the arrays are only a single gameobject without a list of value, instead of a hierarchy array of game objects that it does with 2020.13.
Is this a known issue, or does it work differently with arrays now? Possibly because of the OPCUA change in 2020.14?
Yes, arrays are not supported currently. We will add this in one of the next releases. If you need it at this moment you should go back to the old version.
GOOD, I'M SATISFIED
Satisfaction mark by Neil 5 years ago
