Could I write I0.0 into PLCSIM?
Stupiddog 4 years ago in realvirtual.io Starter and Professional • updated 4 years ago • 2
Hello Thomas,I can connect Unity to PLCSIM S7-1200 CPU via nettoplcsim,and I can read Q0.0 and write I100.0,but I can't write I0.0,what should I do if I want write I0.0 from Unity to PLCSIM?Thank you very much。I have set Get/Put and export Symbol Table,but I can't write I0.0 into PLCSIM,if Iwant to make a virtual PLC like this,what should I do?
Image 625
Image 627
Image 629
Hi, this issue is not known from our side. Are you sure that you are not overwriting I0.0 from somewhere else?
Hello Thomas,I move the I address from 0.0 to 100.0 then I can write I0.0 value and cannot write I100.0 value,but I don't need use I100.0,thank you。
