spaceNavigatoer error mac
Kadir 4 years ago in General Questions • updated by Support 4 years ago • 10
despite removing the spacenavigator file in unity i still have problems.
Image 660
Image 661
Solution is to delete the folder
Assets/game4automation/private/RuntimeUI/SpaceNavigator
and to change in the Script SceneMouseNavigationCs the following compile swith at the top and at the end of the script:
#if ((!UNITY_IOS && !UNITY_ANDROID  && !UNITY_EDITOR_OSX) || UNITY_EDITOR)
against this:
#if (UNITY_EDITOR_WIN || UNITY_STANDALONE_WIN)
This will exclude Space Navigator from being used by non Windows Systems.
After doing this you need to select manually again (because automatic installation script was not started due to the compile error) Apply Standard Settings:
Will be changed in the next release.
Hi, please remove the whole Spacenavigator Folder, this should resolve the problem.
i did, it still dont work.
Can we look on your Screen with Teams for detecting the problem?
sure, when do you have time ?
Hello, sorry for the delay.
we could meet today at 17:00 CET or Wednesday, Thursday and Friday 9:00-15:00.
I could not find your account in teams. Do you have Zoom?
yes today 17:00 CET is fine. Yes I have Zoom - please send an invitation to thomas@realvirtual.io
okay. i sent an invitation. thank you!
against this:
@Brian: Did you also made the changes in SceneMouseNavigation.cs as described below?
