Fertiggestellt
Hello Thomas,I can't connect to S7 Interface if I have many Signals。
Stupiddog vor 4 Jahren • aktualisiert von Support vor 4 Jahren • 3
Hello,as you can see,I have an Arduino Mega 2560 and I want to do my own PLC,the PLC has 24 DI、24 DO、8 AI、8 AO signals,when I add all the signals into S7 Interface it can't connect to PLCSIM(I use nettoplcsim),but when I deactivate some signals it works well,if I want it works with all my signals what should I do?I have used the most new G4A,thank you!
Image 674
Image 675
Image 676
Image 677
Image 678
Image 679
Image 680
Hi, the number of signals is not an issue, I have seen models with more than 1000 signals. Have you tried changing (reducing) the MaxPdu Lenth (e.g. to 40). Did you tried the AreaReadWriteMode (but I don't know if that works with nettoplcsim).
Thank you Thomas,I change it to 200 and it works,thank you very much。
