Inspector-items turning grey
Bear 4 years ago in realvirtual.io Starter and Professional updated by Support 4 years ago 6
new here. I looked at the scene "DemoGame4Automation". I want to replicate that in my own project, but have the problem that as soon as I add the "RobotIK"-script and a path and target, all axes under the robot are greyed out. I am also unable to change values in the inspector then. Any solutions to this?
Regards,
Jan
I have checked your upload.
The definition of the axis within the RobotIK component is missing. (see screenshot below).
Please define it and use the option above to update the drives.
There was also an error message in the console pointing in this direction.
Image 842
Hi, we do this if we do the IK preview in edit mode. Normally when you get out from a path or a target the items should be editable again.
Or you turn off the prieview mode here in the targets:
Image 838
Hello again!
The above mentioned didn't work. Here is a screenshot of the problem:
Here is another position:
Image 842
would you please upload your project here: https://realvirtual.transfernow.net/de/push ?
That way we can check where the problem is coming from.
is it public or will it be transferred only to you?
I'm asking because of privacy reasons...
The upload is only available for us and will be deleted automatically after 30 days.
