Import nodes remains importing for ever
Elio vor 4 Jahren in realvirtual.io Starter and Professional • aktualisiert von Support vor 3 Jahren • 3
fallo_opc_prosys.pcapng
Hello all,
My application gets stuck when trying to import nodes in Unity3D from the Prosys OPC UA Simulation Server. It shows a window saying "Hold on... Importing assets", but it never ends. Here is a capture from Wireshark showing the messages exchanged. Any ideas?
Hi, we have found a solution for Prosys. It was a problem with the underlying OPCUA library. With this setting we are now able to import (you need to select a topnode). It will be included in the next release (2022.11). Please get in contact with us if you need a beta earlier.
Image 1042
You might have an extreme number of nodes in your opcua server. Please limit it by selecting a topnode-id which has lower number of nodes.
Image 1042
