Fertiggestellt
Robot IK Edit windows Lost
yangkang vor 4 Jahren • aktualisiert von Support vor 4 Jahren • 5
Hi
Today, after I opened the scene, I found that their editing window did not display, such as the path of the robot, joint restrictions of the robot, etc. I exported the project to another computer, and it displayed normally after opening. Meanwhile, I also tried to restart the project, but it didn't seem to work.
Image 860
Image 862
Today
Image 861
Yesterday.when i click Path,the Path Line show normaly
Hmmm - I can't reproduce your behavior. Do you have example projects where we can see that?
I mean fixer release Siginal is true,but it also can fixed MUs, i dont know why
Image 869
problem video
Please , i am confused long time,,,
problem~1.mp4
I am not shure if this is the problem but when fixing with signals - fixer is only doing things when signal is changing from low to high. so fixer should move in - then fix signal should get high (while unfix needs to be kept low) and then the part should be gripped.
Please check the demo , they should give you some examples how it works
Image 871
