Abgelehnt
Direction vector disappeared
Bo Adam vor 3 Jahren in General Questions • aktualisiert von Support vor 3 Jahren • 8
I used to have the purple direction vector of a drive visible in the scene window when selecting a component with a drive, but now it disappeared. Do you know how I can get it back?
Fertiggestellt
please check if the gizmos are enabled and check the scale of them.
Regards Christin
    Fertiggestellt
    Regards Christin
      The gizmo option is enabled for the drive. The gameobject that the drive is attached to is static, does that matter? It used to work in the past. How can I check the scale of the gizmos?
      Can you send us the project via realvirtual.io/send (please delete the library folder before) and we will debug it, to detect why the vector is not displaying on your side.
      A colleague of mine found the problem!
      Thanks for helping.
      check the screenshot below. With 3D-Icon you can scale the gizmo size.
      Image 929
      Regards Christin
      I've enlarged it to the maximum and changed te color, but still the arrow won't show up. Is there anything else i can try?
