Assertion failed on expression: 'CompareApproximately(SqrMagnitude(result), 1.0F)'
R S 3 years ago in realvirtual.io Starter and Professional • updated by Support 3 years ago • 2
I played the project on the "Game" screen. However, when I click the right mouse button, I get the following error and nothing is rendered on the "Game" screen.
- Assertion failed on expression: 'CompareApproximately(SqrMagnitude(result), 1.0F)'
UnityEngine.Quaternion:Internal_FromEulerRad (UnityEngine.Vector3)
- transform.position assign attempt for 'Main Camera' is not valid. Input position is { NaN, NaN, NaN }.
UnityEngine.Transform:set_position (UnityEngine.Vector3)
Ubuntu22.04, Unity 2022.3.7f1, realvirtual.io Digital Twin Professional 2022 Ver.2022.6.0Ubuntu22.04, Unity 2022.3.7f1, realvirtual.io Digital Twin Professional 2022 Ver.2022.6.0
Screencast from 2023年08月16日 23時43分29秒.webm
Got it - Linux is not supporting Screen.dpi. You should insert this in line 456 in SceneMouseNavigation. It will be part of the next release in 3-4 weeks, for the moment you should change the code manually.
#if (UNITY_EDTOR_LINUX || UNITY_STANDALONE_LINUX)
DPIScale = 1;
#else
DPIScale = 144/Screen.dpi;
#endif
You are right - this happens only on Linux - will need to check and get back to you.
DPIScale = 1;
#else
#endif
