OPC UA reconnects only once, Realvirtual professional
dgcrt 3 years ago in realvirtual.io Starter and Professional updated by Support 3 years ago 4
Good morning,
We are having problems with the OPC UA connection.
When the OPC server is turned off and on again the connection is reestablished correctly, but only once since startup, if the server disconnects a second time the connection is never reestablished.
How can we solve the problem?
Thank you.
Will need to check this with the demo server.
The issue is solved. Will be in the next release 2022.10.
Thank you very much,
I also need to update some old projects, can you give me a compatible package?
I have the following errors:
GUID [3d96742c5d0f55549bf82465111f489d] for asset 'Assets/game4automation/private/Interfaces/OPCUA4Unity/Demo/DemoOPCUAwithRealvirtual.unity' conflicts with:
'Assets/game4automation/private/Interfaces/OPCUA4Unity/Demo/DemoOPCUAwithGame4Automation.unity' (current owner)
Assigning a new guid.
GUID [4d7ad52e4ad89a642a093e6378767577] for asset 'Assets/game4automation/private/Interfaces/OPCUA4Unity/private/Editor/realvirtual.interfaces.opcua.editor.asmdef' conflicts with:
'Assets/game4automation/private/Interfaces/OPCUA4Unity/private/Editor/game4automation.interfaces.opcua.editor.asmdef' (current owner)
GUID [94e27011e75a3b54996a6184f4954e89] for asset 'Assets/game4automation/private/Interfaces/OPCUA4Unity/realvirtual.interfaces.opocua.asmdef' conflicts with:
'Assets/game4automation/private/Interfaces/OPCUA4Unity/game4automation.interfaces.opocua.asmdef' (current owner)
Folder 'Assets/game4automation/private/Interfaces/OPCUA4Unity/private/Editor/' contains multiple assembly definition files (Assets/game4automation/private/Interfaces/OPCUA4Unity/private/Editor/realvirtual.interfaces.opcua.editor.asmdef)
Folder 'Assets/game4automation/private/Interfaces/OPCUA4Unity/private/Editor/' contains multiple assembly definition files (Assets/game4automation/private/Interfaces/OPCUA4Unity/private/Editor/game4automation.interfaces.opcua.editor.asmdef)
Folder 'Assets/game4automation/private/Interfaces/OPCUA4Unity/' contains multiple assembly definition files (Assets/game4automation/private/Interfaces/OPCUA4Unity/realvirtual.interfaces.opocua.asmdef)
Folder 'Assets/game4automation/private/Interfaces/OPCUA4Unity/' contains multiple assembly definition files (Assets/game4automation/private/Interfaces/OPCUA4Unity/game4automation.interfaces.opocua.asmdef)
I think you will need to delete fully old OPCUA folder and then import the new unitypackage.
