Reading a NULL value causes disconnection
Ege 3 years ago in OPCUA4Unity • updated by Support 3 years ago • 2
Every time a node I'm subscribed to is read as null, the client disconnects. The type of the node I'm trying to read is a float if that matters.
OPCUA Interface - Subscription with ClientHandle 78 Value Changed ns=2;s=NodeA Value [25,1]
OPCUA Interface - Subscription with ClientHandle 80 Value Changed ns=2;s=NodeB Value [140305,5]
OPCUA Interface - Subscription with ClientHandle 80 Value Changed ns=2;s=NodeB Value [140207,5]
OPCUA Interface - Subscription with ClientHandle 88 Value Changed ns=2;s=NodeC Value [NULL]
OPCUA Interface - Client Disconnected
This happens with any node, whenever a value is written as [NULL]
Any help would be appreciated about how to make it so that the program doesn't crash.
Thank you.
We will need to check this. Can you send the full log - do you know in which line of code it is crashing?
