IK Path could not complete the execution
haoyu yi (Hari) 3 years ago in realvirtual.io Starter and Professional • updated by Support 3 years ago • 3
Now I have created two paths A and B using IK Path, when I repeat the signal quantity given to start for each path individually the paths can be executed correctly, but once I execute A and B alternately the paths are unreachable.
For example, I am using Signal Start to get path A to start moving, and Signal Ended to get if path A has finished executing. When Signal Ended is true for A, I start executing path B. It happens that path B can't finish execution and Signal Ended stays false.
This results in me not being able to control the robotic arm by itself to do the job I want to do, how can I solve this problem?
vedio:
https://imgur.com/wrUQm03
As you can see from the video, Path alone can be fully executed at first, but once I execute Path A and then Path B, PathB can't complete all the actions.
Could you please upload us your full project for testing it on our computers:
https://realvirtual.io/send
