Meta Quest 3 VR Main Camera
jf9 vor 3 Jahren • aktualisiert von Support vor 3 Jahren • 3
I have a question regarding the Main Camera in the realvirtual gameobject. I've searched through the forum and saw a 3 year old post where you suggest to just delete or deactivate the realvirtual main camera. When I do that, the realvirtual controller script component in the realvirtual gameobject deactivates itself. What i did for now is increasing the rendering priority of my XR Origin Main Camera to avoid issues. Is there a better solution to this?
Image 1044
Image 1045
I don't know which version you are exactly using. Just deactivating the Gameobject with the Main Camera should work.  Can you send me the line of code which is creating the null reference. Maybe a null check there is helping.
2022.07.3438 (Unity 2022.3.2f1)
Image 1046
Please change it like that - it seems that you are using an old release:
if (currentSelectionRaycast != null)
currentSelectionRaycast.IsActive = false;
