Transport surface make the conveyor texture mismatch
ULE 3 years ago in realvirtual.io Starter and Professional updated by Support 3 years ago 3
I don't know how to use transport surface, I notice in the demo scene the conveyor belt works perfectly, but in my scene everytime I tried turn the whole conveyor 90 degree but the texture dose not follow and still goes as before. How do I fix this?Video
It is an old version of realvirtual (still game4automation) we fixed a lot. You should upgrade to the latest release.
Will be answered
Maybe it is just an animation issue - can you try changing the texture scale setting in transport surface.
I tried change the transport direction in transport surface, its not good since it also alter the object movement direction. Then I change the texture scale but this will only make the texture move faster to a wrong direction .......
