HMI UI not showing in Play mode
Maira Matos 3 years ago in realvirtual.io Starter and Professional • updated by Support 3 years ago • 3
I created an HMI object with 2 HMI tabs. The first tab stores a drop-down menu, and the second tab stores 3 HMI Panel World Space with HMI buttons. When I use Unity in Scene and Game mode , I can visualize the changes. However, after starting the simulation ( Play mode ), all the objects inside HMI wont appear on the game. All elements are on the UI layer.
Scene Mode
Image 1094
Game Mode
Image 1096
Play Mode
Image 1097
after reviewing your images again, it appears that you're not using tab buttons to switch between the tabs. In this case, please enable "Tab Activated" within the "HMI_Tab" component to activate the tab when "Play" is started. Let me know if this solves the problem.
Regards Christin
hard to say - would need to debug to see what setting can cause this - see the properties of HMIVRG and components below during runtime.
Regards Christin
