Help doing a basic project.
G Tardio vor 3 Jahren in General Questions • aktualisiert von Support vor 3 Jahren • 6
I want to do a project that looks like the demo, but i have tried to do it modifying the demo but i have no clue. I am looking on how to do a conveyor with a sensor at the end. I want to make two sources, two cans with different heigts, one one (i would like to make them appear random, but that i will try to do it further along the project since i guess is harder). Then the ones that are high enough to make the sensor go on, to grap them and put them on a parallel conveyor. When a can touches the first conveyor, i want the conveyor to stop until it is picked up.
later on, i would like to connect this to a plc siemens, so i would like to get started this project by projecting it on this goal (meaning to put the sensor as an output, something like that)
I am looking for help to put me in the path on completing the project because i do not know how to start and i have watched the tutorials. Any help is appreciated.
thank you
please take a closer look at our demo scenes. You'll find simple scenes to kickstart your project. To model the handling and start/stop functionalities, you'll need to create your own script. The demo scene offers an example that you can also use (GameObject: PLCs). To connect a PLC, realvirtual professional is required. For training inquiries and quotes, please contact info@realvirtual.io.
Kind regards
Christin
But it says that i can connect them to siemens s7-1500
The Starter version only includes an S7-TCPIP Interface to connect via TCP to real Siemens Controllers: S7-300, S7-400, S7-1200, S7-1500, Sinumerik or Simotion and a Siemens Simit interface.
Also, if i have the siemens license to the virtual plc s7-1500v siemens  can i use it? or do i need to buy the pro?
just to clarify, the Siemens interfaces you mentioned are included in the starter version. You won't need the professional version for this. Apologies for any confusion.
Kind regards
Christin
Even the conexion to the virtual PLCSIM ?
no, this connection is only in professional
you can check the the table here for a feature comparison:
https://realvirtual.io/en/buy/
