Why PlcSimAdvanced doesn't connect to plc markers
I realized that PlcSimAdvanced isn't importing plc marker signals. Only Inputs or Outputs.
Is there really no way to use markers or data block signals?
Andreas
I don't think that there is a way for doing this. It is also a little bit "against" the simulation logic. Markes can't be read from external devices in real systems. You could use S7 interface maybe instead.
