Gripper.cs - Bug with 'grippedonclosing'
Andreas vor 2 Jahren in realvirtual.io Starter and Professional • aktualisiert von Support vor 2 Jahren • 1
I am trying out the Gripper.cs component and faced a problem with the variable 'grippedonclosing'
After gripping a MU this variable gets set but reset is missing. This leads to the problem that the gripper keeps closing only to the last grippedonclosing position even if no MU is available.
I added this one code line:
Image 1245
Best regards,
Andreas
thank you for reporting this issue. We will fix this in the next release.
Christin
Christin
