Searching answer
Transport surface rotation axle moved from the centre
m m vor 2 Jahren in realvirtual.io Starter and Professional • aktualisiert von Support vor 2 Jahren • 1
Hello, I've been testing demo scene "MovingTransportSurface". As it is mentioned in the documentation "If the parent drive of the transport surface is rotating, the pivot points (centre of rotation) of both objects must be in the same position for the movement to be transmitted correctly". It is OK if you need to rotate around axle in the centre of transport surface. But I wondering if it is possible to rotate transport surface around axle which is not in the centre of transport surface. It looks like the pivot of the transport surface must be moved, but is it possible to do this?
Searching answer
currently it isn't possible to rotate it off-center. We will work on this for the next release.
Regards Christin
Searching answer
Regards Christin
