Ethernet IP not connecting, Allen Bradley PLC
Kjell Arne Vebenstad 2 years ago in General Questions • updated by Support 2 years ago • 5
I just bought this software to use the Ethernet IP interface to a Allen Bradley, I am up and running in Visual studio using the same Ethernet and can get tags there, but I need it in Unity, please help.
Hi, I think we need a teams support session. We don't have Allen Breadley PLCs here, we checked before release with an US based customer. What is your Time Zone and when could we do a Teams call. Might be that we need to debug in Unity. Is the Console Log in Unity giving any hints?
I got connection now, not entirely sure what the reason was, but I rewrote "1,0" in the path (that was also the default value), so I have tried a lot of different values.. that didn't work. (I also have no reference to what the path number is)
One more thing I bought the pro package for Unity6 can I also have the older version of the plugin, for my older projects?
Thanks for the feedback. If you have some information we can add to the docs that would be very helpfull because we are not AB Experts.
You can use old versions - you should be able to login here and download old releases:
https://download.realvirtual.io/download
Hi, I noticed that the interface will not connect if a INPUT/OUTPUT TAG is not defined or misspelled in Unity.
But the log does not say wish SIGNAL that is wrong, it will just not connect. If I disable that Signal, the test connect works again.
