OPC UA PLC RECONNECT
Virgar Poulsen 1 year ago in realvirtual.io Starter and Professional • updated by Support 1 year ago • 3
If the PLC is disconnected, the application hangs/crashes.
Hi, we are checking and looking for a solution.
Hi, we checked with our OPCUA demo server and reconnection works as expected. Can you describe a little bit more your setup so that we can try to reproduce the issue.
