Fertiggestellt
The "Combine Meshes (Pro)" function cannot be found.
ZhangFengMing vor 1 vor einem Jahr • aktualisiert vor 1 vor einem Jahr • 5
Image 1325
Why can't I find the "Combine Meshes (Pro)" function in the version I'm using? I have purchased the PRO version, so is this function only available in Professional 6?
One more question: Does realvirtual.io Digital Twin Professional 6 require a separate purchase? I noticed that 2022Pro has been discontinued.
Fertiggestellt
This utility was introduced in realvirtual.io Professional 6 and is only available in the Professional 6 release. If you’re still on the 2022 Pro version, you won’t see “Combine Meshes (Pro)” in your menus—this feature doesn’t exist in earlier 2022.x builds doc.realvirtual.io. To use it, you’ll need to upgrade your license and project to realvirtual.io 6.
Is it necessary for RealVirtual.io Professional 6 to be used in conjunction with Unity 6? The Unity 6 version cannot be used in the Chinese region.
Yes it is necessary to have version 6. I did not knew that Unity 6 is not available in China. We will soon put back the old version on the Asset Store.
Thank you very much. We are currently considering how to use the Unity 6 version in China. The way Unity operates is quite strange. After the 2022 version, it will no longer be updated in China, including Unity 6. If RealVirtual.io Professional 6 needs to be used in conjunction with Unity 6, then we need to find a solution. It would be best if the 2022 version of Unity could also use RealVirtual.io Professional 6. We can add a version support and we will cover the cost for this version update.
The official release by Unity states that it will no longer be available for download in China for Unity version 6. This action will cause Unity to lose the Chinese market. So I don't know how to use or purchase realvirtual.io 6
