RV6: How to turn on the scene light?
Andreas 1 year ago in realvirtual.io Starter and Professional • updated by Support 1 year ago • 3
I created a new RV6 scene and imported a model but it seems that the light is turned off.
If the same model gets imported into the demo scene it is illuminated.
How to fix that?
Model in new RV6 Scene:
Image 1335
Model in Demo Scene:
Image 1336
There are a lot of different locations where lightning settings in Unity / realvirtual can be impacted. Usually our realvirtual Prefab is having everything in what is needed.
Please check if our Default Render Pipeline is on:
Image 1337
In realvirtualPrefab in your scene just reset the overrides for making sure that everything is as we defined it in Standard:
Image 1338
Thank you for your response.
There seems to be a difference if the scene is created via File > New Scene > RV Template or if created via Menu realvirtual > Create new realvirtual Scene.
If created directly via realvirtual menu the lightning works just fine.
Thanks a lot - there seems to be a bug in our Scene template. We will take care about it in our next release (which will be end of this / beginning of next week).
