Chain Transfer Issue
Cam vor 12 Monaten in realvirtual.io Starter and Professional • aktualisiert von Support vor 11 Monaten • 4
The normal sample scene works great, as well as the majority of the others! Although I am running into major issues with a few components and other test scenes. The chain transfer sample scene does not work at all. The main issue seems to be the chain does not lift no matter what I try. I've changed many parameters and even tried to use the transfer in my own projects but it will not lift off the conveyor. It shows that its moving 'Out', but no motion actually occurs even with exaggerated positions. I was hoping to just use this chain transfer object as its exactly what I need, but it isnt responding. Any ideas on what I may be doing wrong?  Unity Version 6000.0.61f1
Realvirtual pro version 6.0.7.8152
realvirutal sim version 6.0.5.7954
Another problem is that the chain transfer has no collision detection.
Is solved in current beta - will be available in upcoming Simulation 6.0.7 Release
thank you so much! the chain transfer now appears to be working normally. I really appreciate your help and the fast response!
