IO.Input.Machine.bMachiningFinished ist becomming true
Werner vor 7 Monaten • aktualisiert von Support vor 7 Monaten • 3
I'm using the TwinCAT CNC Demo. The first part of the sequence works fine. The robot takes the part, puts it into the machine and the machine starts.
However it never ends. The IO point IO.Input.Machine.bMachiningFinished never becomes true?
Does anyone have an idea about this?
Thx!
Werner
GUT, ICH BIN ZUFRIEDEN.
Zufriedenheit von Werner vor 7 Monaten
Hi Werner, I will need to check - maybe a problem in the demo scene. The TwinCAT demo was done by a partner and we never tested it fully with TwinCAT ourselves. I will take a deeper look into the mode.
Thank you Thomas! That works now perfectly with the TwinCAT PLC application!
Thank you for your swift help!
ADS vs. OPC UA: while ADS works very well when using TwinCAT, it is very difficult to be used in RUST or Python, etc. I actually don't get it running.
Is there any plan to offer this very nice demo with an OPC UA interface as well?
Hi Werner, currently there is no OPCUA demo planned (OPCUA is not very good performing and sometimes complicated to setup)
