okay
at 18:00 is perfect
I am from Spain and share the same schedule as Germany.
I do not have Teams but I will install it now and I will be connected at 18:00 pm
a greeting
Hello good day.
I was doing tests yesterday with zero tier (1 computer with kepserver the other as a client), I managed to connect two PCs through zero tier but the client cannot connect to kepserver.
I think it's because of the DCOM settings.
I am going to try to configure the DCOMs and I will do tests, when I get an external connection to kepserver with zero tier I will let you know.
I will try to have everything by Monday and be able to tell you an hour.
Thanks a lot
I have done tests with the kepserver simulator
without the omron plc, only with one node and with the same result.
between clients such as opcwatch or uaexpert being both connected if they can write and see the value updated on the other.
It seems fine to me to make a connection with zero tier or anydesk.
Thank you.
in this last photo debug mode is on, in OPCUA_Interface
in the photo I sent from unity the console notice says that I have to disable subscribe value.
I've tried it but it doesn't work either, although the warning no longer appears.
the area "D" where try to write is a memory area and not physical channel.
I also tried without subscribing and it doesn't work either.
I have tried to write booleans in the memories of brands of omron plc and it does not work either.
but all this can be written from opcwatch.
Edu
hello
I give you an example:
- I start the machine
- through opcua I program a product injection time of 5 seconds for example
- I want that time to never change until I personally change it again
-I work all day with the machine
- I turn off the machine
- The next day I turn the machine back on and opcua overwrites that value with 0
- I want it to read the value that the plc has when starting and not modify it
