Thank you, it's working now!
Image 1455
S7 connection failed. I'm getting this error. I'm using the code you sent me.
Hi Thomas,
I was able to resolve the issue in the meantime.
The problem was related to the connection/reconnection logic inside the S7Interface script (Unity 6.3 + realvirtual 6.3).
Specifically, there was a mismatch between the old Time.time-based reconnect handling and the newer async DateTime-based logic.
Because of this, the interface continuously reset its internal state, which resulted in a permanent "Waiting to connect..." status and no communication cycle starting.
Fix (summary):
Removed or adjusted the old reconnect logic using Time.time (_lastreconnect)
Used only the new DateTime-based reconnect handling (_lastReconnectTime)
Prevented the connection state from being reset in FixedUpdate()
Ensured that the async connection (ConnectS7Async) can complete without being interrupted
After this change:
Connection establishes correctly
Thread cycle starts normally
Communication with the PLC works again
So the issue seems to be caused by a state handling conflict in the current version.
Thanks for your support!
