Dear Thomas,
Thank you so much for your reply.
The "Core Task of an Interface" you have mentioned can be realized by the C# scripts provided by the example on Github, as shown in the pictures below. I think it works like the way "Special Interfaces for Robot Axes" you have mentioned, (but I'm not for sure). However, what I would like to do is to use the "Standard Method" you have mentioned together with my EGM interface. You said that "For the moment, you should use any of the existing interfaces as a blueprint and delete everything what is PLC / interface specific.". What does "delete everything what is PLC / interface specific" mean? Did you mean that I should delete the PLCOutputFloat and PLCInputFlost components under the GameObject of my EGMIterface (e.g. the "joints[1]" components in the picture above)? If so, does it mean that I actually can hardly do it in the "Standard Method" way for now, because it would be a rather complex and systematic renovation of a realvirtual.io interface? If so, the way of using "any of the existing interfaces as a blueprint" will be something similar to the C# scripts provided by the example on Github, right?
Due to my unfamiliarity with Unity and the C# language, I have some difficulty in clearly understanding the structure and principles of the project in Unity and the existing interface scripts of realvirtual.io. So, sometimes my questions may be quite silly. If that's the case, please accept my apologies. Thanks again.
Dear Thomas,
Thank you for your reply and advice.
On GitHub, I have found two examples of conducting communications between Unity and an ABB robot through EGM, as shown below, which are pretty close to what I need. And, just as suggested by you, I'm trying to build a EGM interface based on the C# scripts of these two examples with the help of the C# scripts of the UDP, the ABB RobotStudio, and the S7 interfaces provided by realvirtual.io.
https://github.com/rparak/Unity3D_ABB_IRB_120_EGM
https://github.com/fronchetti/egm-for-abb-robots
My first-step goal is to use RAPID code to control the actual motion of the real robot, and transmit the joint information of the robot in real-time to Unity through the EGM protocol, thereby achieving virtual-real synchronization without feedback control. After achieving this goal, then find a way to solve the virtual-real synchronization with feedback control.
However,I'm facing a rather tricky problem now:
In those two examples, the robot control part and the EGM communication part are mixed in a single C# script. However, in my realvirtual.io scene, the robot control part are realized by the robot-body components associated with the Driven (Script), the Rigidbody, and the Driven_Follow Position (Script), while, the EGM communication part is supposed to be realized by my EGM interface. As far as I know, the connections between my EGM interface and the Driven_Follow Position (Script) component should be some PLC Output Float (Script) and PLC Input Flost (Script) components. But I don't know how to let the PLC Output Float (Script) obtain the real-time joint information of the robot read through my EGM interface. I have checked the the C# scripts of the UDP, the ABB RobotStudio, and the S7 interfaces provided by realvirtual.io. I found that, in the C# script of the UDP interface, there is no special definition is required for the PLC Output and PLC Input components. Integrating the PLC components directly under the UDP interface will be okay, just as shown by the UDP demo. However, for the ABB RobotStudio and the S7 interfaces, some PLC-related statements are necessary in the C# scripts. More importantly, the naming conventions for the PLC components in the three types of interfaces are different from each other.
I'm quite confused about how to communicate between my EGM interface and the robot component through the built-in PLC components in realvirtual.io. Hope you can give me some further adivce about how to configure the PLC components with a custom interface in realvirtual.io.
Dear Thomas,
I'v finished the EGM interface based on the UDP interface of realvirtual.io. And here is my first Digital Twin of an ABB robot.
Reavirtual.io is really awesome~ Thanks a lot~
Digital Twin ABB.mp4
