When will Unity 2019 be supported?
Stan 6 years ago in OPCUA4Unity • updated by Support 6 years ago • 5
I was wondering when will OPC UA for Unity 2019 will be supported?
With kind regards,
Stan (Developer at Siemens)
Hi, we have no tutorial about that.Even if Unity 2019 is not officially supported yet, you should be able to get it running. What is your problem. What kind of error messages do you have?
GOOD, I'M SATISFIED
Hi Thomas, thanks, we got it working in Unity 2019. The reason I asked the question in first place, because on the Asset Store you mentioned that it only works in Unity 2018. But it is solved now.
Satisfaction mark by Stan 6 years ago
Hi OPCUA4Unity and Game4Automation will support Unity2019 officially as soon as there is a LTS release for 2019 available.
But it already works with 2019 unofficially - we just don't support if there are special problems.
Can you help me connect OPC UA with Unity2019 ?
Hi, what is your problem. What kind of error messages do you have?
I have project which need connect OPC UA with Unity2019 . Can you give me a tutorial or videos about it?
