Fertiggestellt
It is possible to drop the can in any position?
Juliano Cortes vor 6 Jahren • aktualisiert von Stupiddog vor 5 Jahren • 3
I want a very realistic physics to simulate the robot taking a can and dropping the can when the gripper is opened. It's possible?
You will need to set the Values "PlaceObjects" or the corresponding values to true to loose the can. If you use PickBasedOnCylinder this can be controlled by a connected cylinder. So the Can should fall down whenever you open the Cylinder.
