OPC UA without Top Node ID
Werner Paulin vor 6 Jahren in OPCUA4Unity • aktualisiert von Support vor 6 Jahren • 4
I'm trying to connect via OPC UA to a Node-RED OPC UA server. This server allows me to create nodes on root level.
Image 241
If I do not specify a Top Node Id I get the following error:
Image 242
Is there a way to connect to nodes I've created as shown above?
Thanks
GUT, ICH BIN ZUFRIEDEN.
Zufriedenheit von Werner Paulin vor 6 Jahren
This should work. Are you not able to import the signals with an empty top node ID?
No. I get the error message "NullReferenceException".
It actually works if I specify an endpoint at the OPC UA server:
So, instead of opc.tcp://localhost:4840/ I specified opc.tcp://localhost:4840/Test.
So far this is ok for me.
