OPCUA4Unity can't connect to opcua server with username and password
penjami rantakangas 5 years ago in OPCUA4Unity • updated by Support 5 years ago • 5
Anonymous connection works fine, but when using a username and password, the console doesn't show any errors in creating the connection, but I am not able to read or write to nodes. Also the server doesn't acknowledge the connection. Even when using application certificates the connection doesn't work properly. Using OPC Watch or UaExpert I can easily connect to the server with the username and password.
Unity is connecting successfully but afterwards no nodes are available when the connection is done with a username and password. Are there any special security settings on the nodes itself in the server which could prevent the reading when loggin in with a user?
Will need to ckeck. Are you able to share your server for testing ?
I sent the test server as a private ticket message.
Yes, received it - will work on it tomorrow.
