Axis with encoder
je-a-s vor 5 Jahren in General Questions • aktualisiert von Support vor 5 Jahren • 2
is there a sensor type encoder ?
... and if you need a pulse encoder - sending pules every xxx millimeters, this will be available in one of the next releases. If you are a customer and purchased a professional version - please send us an email to info@game4automation.com with your Invoice and we can send you a beta of the pulse encoder.
I assume your question refers to a drive. In this case you can get the information directly from the drive by using the attribute "Current position". The handling of this
take place in your own C# script which you attach as a component to the game object where you need the information.
