Error importing the Package
rexgatling1988 vor 3 Jahren in realvirtual.io Starter and Professional • aktualisiert von R S vor 3 Jahren • 5
I get this error when I import the package to Unity:
Assets/game4automation/private/RuntimeUI/SceneMouseNavigation.cs(801,38): error CS0103: The name 'SpaceNavigator' does not exist in the current context
Is fixed in latest release.
Hi, which version of Unity are you using. Are you working on a Windows System or Mac or Linux?
Image 940
I get the same error.
Ubuntu22.04, Unity 2022.3.7f1, realvirtual.io Digital Twin Professional 2022
The following error occurred immediately after importing, but the error disappeared when the project was reopened. 3Dconnexion drivers don't seem to matter. There seems to be no problem for now.
- Unable to update following assemblies: Assets/realvirtual/CADLink/private/CMC-Kiesel/Plugins/CMCKiesel.UnityNativeImporter.dll (Name = CMCKiesel.UnityNativeImporter, Error = 131) (Output: /tmp/tmp9958fe.tmp)
- Unable to update following assemblies: Assets/realvirtual/CADLink/private/CMC-Kiesel/Plugins/CMCKiesel.UnityNativeImporter.dll (Name = CMCKiesel.UnityNativeImporter, Error = 131) (Output: /tmp/tmp3b6e91b1.tmp)
Image 955
It seems that the SpaceNavigator driver is the cause. I was downloading the driver from the following URL. https://github.com/FreeSpacenav/spacenavd
I would try changing the driver to:
http://www.3dconnexion.com/service/drivers.html
Image 943
