OPCUA_Interface with Kepserverex Windows 11 communication issue
Dear all,
I experienced a problem when connecting with Kepserverex OPCUA server through OPCUA_Interface in windows 11.
When I specify the IP address in the OPCUA_Interface, the following error appears:
Looks like the problem is in line 133 of the OPCUA_Interface script:
IPAddress ipAddress = Dns.GetHostEntry (ServerIP).AddressList[0];
If I remove this instruction, then the communication seems to be established.
This issue doesn't happen when running the same version of Keperverex and Project Unity in Windows 10.
Have any one experienced this issue?
Thank you in advance!
Hi, I don't know this issue but we will check for the reason.
Thank you Thomas. I look forward to your findings.
In addition, I'm experiencing huge lags because of the communications working in Windows 11 (removing the commented line 133 to allow communication with the Kepserverex):
It should work like this (performance of the same project working in Windows 10):
Any idea?
